advice build for spirited mountain driving
Ive read a lot of similar advice recently and when so many owners say this is the formula I suppose that's the way to go or wander into the weeds at your own peril! As far as suspension and brakes and so on they are on the table for improvements.
When I say spirited I don't mean at the limits, more like satisfying to drive , and when I say not at the limits that means more like there is no guard rail and that drop looks like ten stories!
So far I have a new wiper linkage after working to free up the old one it wasnt as good as i hoped and got some Zrod amsoil to do an oil change on it, the timing belt kit from AR with the pump and bearing--dont want to push my luck with that. The gauge lights are a little weak and the speedo light likes to go out but i just got new bulbs to look into that. just getting started
- chrisg
- Your car is a: 1971 FIAT
Re: advice build for spirited mountain driving
the usual recipe for a '79/80 carb'd car would be the single plane '74-'78 (?) intake with 34DMSA (or 34ADF, or 32/36 DFxV) and replacing the exhaust (unless it already has this) with one of the 4-2-1 exhaust manifold/downpipe setups...and I guess while you're at it, new exhaust with nothing more than a resonator & rear muffler (I believe AutoRicambi sells a very nice one....the PO installed it on my '73 124). From my own experience with that terrain (lower elevations, different geologic feature...southern Appalachians here), I'd say making sure you have correctly clean/lubricated brake components, fresh suspension bushings and ideally a rear anti-sway bar, Konis on all 4 corners, stainless braided flexible brake lines & nice front pads (Green stuff is my go-to) all make it more fun. I think a social media 124 group actually hit on all this just yesterday, come to think of it. All of that will bring your car to what many would say it is or should be in stock form & then other modifications would give it more grunt/etc.....like a 1.8 head and/or higher compression pistons, then matched with cams perhaps, dual carburetors, etc. etc....but, truthfully, doing that first round of stuff (which relatively speaking isn't expensive nor is it rocket science to do) will bring about a profound change in how you experience the car.
Chris Granju
Knoxville, TN
Knoxville, TN
Yours is one situation where a 4.3 rear axle might prove beneficial. Second-to-third and third-to-fourth are rather widely spaced, and a shorter axle ratio would help offset this, keeping you in the power band.
How much do you want to spend? About $5000 will get you oversized pistons (re-bore) worked 1800 head/valves, shaved flywheel, after market cams, adjustable cam wheels, degree'd in properly, 34 ADF carb, headers This will get perhaps 125-135 HP me thinks.
Perhaps consider a budget and see what can be done.
As mentioned, the 79 benefits substantially with bolt on improvements. I helped a fellow here years ago install a single plane intake and a 34 DMSA carb.( on a 79) That woke the car up compared to what it was.
These cars are not a neck snapping performance machine but I have enjoyed the engine improvements and upgraded the suspension, wheels and tires ( 205/50-15's) The car sticks well in the twisties. The brake upgrade is next on the list.
- Your car is a: 1980 Spider
Narfire,
I know I should start my own thread, and I will sometime soon, but . . . I thought of going this route myself. I also have a 1980 Spider but mine is fuel injected. Every time I turn around (the latest was at a shop that specializes in performance upgrades) I pretty much get told that anything I do will be limited by the fuel injection: it is the "choke point." I am told that I need to either do MegaSquirt or some other such fuel injection upgrade, or go back to carburetors. Any thoughts? (you, or any of you other 'performance experts' out there).
- joelittel
SeattleSpider wrote:Narfire,
I have an ‘80 that used to have the stock Bosch L Jet. For years I got the same advice as above, so I upgraded to the VAS programmable fuel injection system.
Here’s the funny part... as soon as my upgrade was complete the advice I was reading had shifted to, “You don’t need pfi the Bosch system is good enough to handle XYZ and ABC upgrades.”
Not sure what or who to believe but I love my programmable setup and monkey around with it often.
I think you may be right the combo of moderate perf upgrades and the lower diff gearing might be the ticket. Ive read some of your engine stuff -very interesting.baltobernie wrote:Yours is one situation where a 4.3 rear axle might prove beneficial. Second-to-third and third-to-fourth are rather widely spaced, and a shorter axle ratio would help offset this, keeping you in the power band.
Joe Little,
Thanks for the response. Did you look at the MegaSquirt as well? . . . and if so, for what reason(s) did you choose Vick's programmable fuel injection system over the MegaSquirt?
- nelsonj
I put on performance (lowering) springs when I changed the shocks. The combo made a significant improvement. You might want to consider new springs as well.
Peace.
Out.
Peace.
Out.
Simi Valley, California
Spider 1800
Romans 10:9
A lightened flywheel makes a huge difference too. Single best mod made on my car.
- joelittel
SeattleSpider wrote:Joe Little,
I did look into building my own Mega Squirt board but ultimately decided that it was a time versus money issue. To learn enough about Mega Squirt to build my own would take me a lot of time, but saving enough to buy the VAS setup would probably take just as long. I felt safe knowing Vick’s would back their product if something wasn’t right, whereas if I built the board and then ruined it with a simple mistake I’d be SOL.
In hindsight, building the board would have given me a more thorough understanding of my car, but I can always read up and research later.
I was also attracted to the “plug and play” aspect of the Vick’s system, but I will say that mine wasn’t so simple. My wiring did not match the diagram I got from Artigue or the instructions I got from Vicks. My advice there is to pay little attention to the wire colors and make your decisions based on which terminals the wires connect to. My car had the correct colored wires but they were not connected as the diagram shows. It took me an embarrassingly long time to figure this out.
From what I understand now, there is a lot of information that needs to be burned into your cars cpu before it will even start, let alone run well. Getting that information seemed daunting to me so I chose to buy that knowledge from Vick’s. I also discovered that you cannot simply take someone else’s tune and expect it to work with your build. It’s best to start with a general tune and finesse it from there.
I had a great experience with Andy at VAS. I know just enough about my car to mess it up pretty bad but Andy walked me through all my issues, both over the phone and via email. I wasn’t convinced that I’d receive the same support when building a MS board on my own. I don’t know that for sure but Andy had helped me in the past so I felt more confident going with Vick’s.
Definitely check out the DIYautotune site before you decide either way. It’s a great resource and those folks may have literally written the book on this topic.
I’d also be happy to help or share anything I’ve learned along the way, just pm me if need be.
All in all I love it
- chrisg
I have a friend who is a bit of a wiz at all things megasquirt...though I'm not actually so interested (I prefer carbs even if they aren't as efficient!), I'll probably end up taking him up on his offers to do a megasquirt conversion on one of my Fiats (probably one of the 124s, so a twin cam). According to him, the cost would be about 600ish bucks in materials & he has all the resources to fabricate literally anything I'd ever want (and maybe some stuff I don't want)....but on the other hand, when I told him that a dual IDF setup is typically more money, less efficient, but sexier & more fun to play with, he completely understood!
Chris Granju
Knoxville, TN
Knoxville, TN
Joe Littel, (sorry about the “Little” in an earlier post . . . thank autocorrect . . . must be frustrating),
Want to thank you for your info and offer of support. I am going to do a little more researching around (including following this post as it develops) to figure out exactly what I am going to do. I am putting this aside for the holidays and then looking at it more closely in January (hope to get some things done before driving season opens up here in the "wet country"). May even do a post of my own. You will probably hear from me in January – mean time: Happy Holidays!
BSmith79: for your carbureted version I think chrisg and narfire have some great ideas (don’t know much about the rear-end/differential). You might also look at the headers and exhaust system for sale by Allison’s Automotive: http://allisonsautomotive.com/wp/ Looks pretty great.
I look forward to watching this post unfold, and to hearing what you decide to do.
John
John
BS Smith79.....to start, snoop around for a single plane intake and a 34 adf, 32/36, or a 34 dmsa carb. That alone will make a difference and won't break the bank. I believe the exhaust is the 4-2-1 so should not be an issue but if you have the restrictive 4-1, swap that out as well.
Seattle Spider, I have the 80 FI as well and still have the stock Bosch FI. Really reliable and easy to work on if for whatever the reason it needs to be fiddled with. I'm a believer in if you really want great performance, although it can be done with these engines with a ton of loot, take a look at a Honda S-2000. Me thinks you would be way further ahead with a car that is designed from the outset for this kind of power and suspension. Up grading a car designed in the 60's might take a while and would everything be in sync with the more powerful engine...upgrade tranny, rear end for example.
On my FI, I had some head work done and installed Mark Allison's FI cams with the adjustable cam wheels and degree'd in properly.
That alone woke the car up . Lots of torque. Driving at 60 kph in 5th and add power , the car picks up nicely without having to down shift...
The car does not snap the head back like my 2017 Golf R but is a gas in the twisties and has enough power to keep things interesting( my guess 125?hp) I get the most satisfaction with the springs ( were IAP Reds) and Koni Yellow shocks and 15" wheels and 205-50 tires. Put a 1" front sway bar on as well. Considering a rear bar and upgrading the brakes this winter.
