Engine Bay Gallery! Please add your own!
Re: Engine Bay Gallery! Please add your own!
I think a bright red works pretty well. Rustoleum 2X Gloss Apple Red, holds on plastic.
Redline
Post by Redline »
I quite like the yellow as a unique trait share on many old Fiat motors. Makes me smile each time I open the hood.
http://www.124bc.com
chrisg
Your car is a: 1971 FIAT
Post by chrisg »
nice BC! is that a 123 distributor?
Chris Granju
Knoxville, TN
Redline
Post by Redline »
Yes, it's from 123ignition in the Netherlands.
Texsardo
Your car is a: 1978 Fiat Spider Convertible 1800
Contact:
Post by Texsardo »
Just a guestion. My engine is black. Its in fair condition. Has anyone ever used truck bed liner paint? Would it be too dull ? Engine components are red, black, polished aluminum. :mrgreen:
Texsardo
Contact:
Post by Texsardo »
Sorry forgot to load photo. I am questioning if anyone has used truck bed liner paint on compartment.
http://rs30.pbsrc.com/albums/c332/texsa ... 0&fit=clip
And after but not finished.
Here's an 84 engine bay, we're just finishing up the installation of a performance head with port and polish, FI street cams, oversize valves, MLS gasket and head stud kit.
and with the final details wrapped up;
RMaxfield
Re: Engine Bay Gallery! Right after rebuild
Post by RMaxfield »
Here is my engine right fter rebuild without cleaning up. Still a lot of work to go but it is super smooth and purrs!
v6spider
Post by v6spider »
Got a new stainless flex radiator hose for Christmas!Image
Cheers!
Rob
http://www.v6spider.com
Sparky
Your car is a: 1978 Fiat 124
Post by Sparky »
kmac33 wrote:Try to guess which is before resto-mod and which is after.
I found one of those timing belt covers in the collection of spare parts that came with one of my Spiders and I've been wondering if it was even for a Spider.
kmac33 wrote:Image
I'll have to look around for some of your other posts. I'm curious where you found that radiator (cross-flow with the rear-ward neck for hood clearance, nice!) as well as how your cooling system is plumbed as you've eliminated the T and extra coolant hoses. Did I read you're running a Microsquirt as well?
Overall, what a great looking engine bay!
-= 1978 Fiat Spider =-
ebrown0104
Your car is a: 1977 Spider
Post by ebrown0104 »
Sparky wrote: I'm curious where you found that radiator (cross-flow with the rear-ward neck for hood clearance, nice!) as well as how your cooling system is plumbed as you've eliminated the T and extra coolant hoses. Did I read you're running a Microsquirt as well?
I did the thermostat conversion on my car also, and for the thermostat housing I found one on eBay for around $40 or so, but they are relatively rare. The thermostat, gaskets, and top hose came from Autoricambi (part #'s CO3-425, CO9-413, GA1-402) and the bottom hose came from Rock Auto (Gates part #21897).
PhillySpider
Post by PhillySpider »
fiatmike124 wrote:Finally at a point when I can post pictures in this thread....
Just starting to look into silicone hoses...what are the sizes? I've seen 4mm, 12mm etc...how many feet of each etc? Thanks!
Odoyle
Post by Odoyle »
Factory 83
jefftobrocke
Your car is a: 1977 spider
Post by jefftobrocke »
Jeff
1977 Spider
2010 Honda Pilot
1964 Galaxie 500 conv.
