I want to replace the wood around the instrument on the dash and glove box, etc. What kind of wood was used in the 1973 Spider?
Thank you
Ron
wood panels
- Your car is a: 1974 Spider
Re: wood panels
I would look for a marine plywood as it is less apt to delaminate when exposed to weather.
Re: wood panels
You might consider veneering over the existing dash panels, there are a few threads here and it is not very difficult. Then you are assured the original fit.
Here is an applicable thread:
http://www.fiatspider.com/f15/viewtopic ... sh#p236276
- seabeelt
- Patron 2019
Re: wood panels
I'm in the process of making some solid Mahogany ones if your interested
- Your car is a: Pininfarina Spidereuropa 1983
Re: wood panels
I use Kahaya (Mahogany) for my dashes. Just finishing up a set for the '83.
I do have a set from my past '75 that may fit. Instrument cluster, 2 strips in the center and glovebox. PM me your address and I can send them to you if you are interested. I made a number of panels that are just sitting around.
- Your car is a: 1967 Fiat 124 Spider
Re: wood panels
I have just finished making mine. I used a top grade marine ply and then veneered the panels.
Ply cut out and test fit
Veneer glued on. Used blade to cut out holes
Finished product
Finished product
