We had our wood mfg make up sets of birds' eye maple. The kits contain the cluster, glove box, shifter plate and 2 small center strips. We have them for 78 and earlier with 6 gauge holes, 79 and later with 5 holes and custom cluster for 79 and later with 6 holes so you can add an oil pressure gauge without eliminating the clock. These are all in stock now at $350 per set plus shipping. Matching shift knobs coming soon!
So Cal Mark wrote:We had our wood mfg make up sets of birds' eye maple. The kits contain the cluster, glove box, shifter plate and 2 small center strips. We have them for 78 and earlier with 6 gauge holes, 79 and later with 5 holes and custom cluster for 79 and later with 6 holes so you can add an oil pressure gauge without eliminating the clock. These are all in stock now at $350 per set plus shipping. Matching shift knobs coming soon!
No love for the 83-85 owners?
Don Avery
Dayton, OH/Sarasota,FL
1985 Pininfarina
2011 Eos
2012 Mercedes E550 Cabriolet
the problem with 83-85 is the center stack is not wood, it's a plastic applied to a metal backing. We've done several 83-85 restorations and we use vinyl wood to redo them.
The glove box door does have threaded inserts for the hinges
Mark thanks for all the custom work. I know it would be time consuming to do but would really help to sell if we could see specialty stuff actually on a car to gauge final appearance. Again i know its quite a bit of work but i think help to see in 'action'
the videos of our restorations are all posted and all of the 84 dashes we've done have been in vinyl.
Here's one example; all of the videos are on my youtube channel. https://www.youtube.com/watch?v=nIY5BDNUVkw
So Cal Mark wrote:the problem with 83-85 is the center stack is not wood, it's a plastic applied to a metal backing. We've done several 83-85 restorations and we use vinyl wood to redo them.
I hear you. I veneered the center stack and am not really happy with the results. The metal is thin and it bends very easily, which cracks the veneer. I'm thinking of making new metal prices for the center console out of heavier gauge metal and veneering again. But then I'm going to have to worry about the vents and switch bezel attaching correctly to the upper center section.
Don Avery
1985 Pininfarina
2011 Eos
