Used a good tank with new pump procured from a forum member, secured it with a modified Simpson "Strong Tie" Galvanized fastener.
Applied another coat of rattle can spray-on Undercoating to the whole under cowl area, including the fastener.
Marked out and cut access hole in cowl with a metal bit in my jig saw. Lined hole with 5/16 slit hose.
Only thing I don't like is having to carve up the original olio Fiat sticker, but hey that's the way it goes.
