Sony amp + 2x 8" subs.. custom box out of 1/2" MDF
The floors torn up so I could remove bumpers etc for paint.
Yes... it does need a little anti-rattle mat
Wife said "no subwoofers if i lose any trunk space - we were both OK with this trade off.
Will the sonics help keep the battery desulfated?scampbel98 wrote:The battery is still there. Unmoved.![]()
It's a flat board in front with speaker boxes to the back for the subs. Each cavity was like .9 cu.ft. which was just enough per the subwoofer specs. (you have to have specific air volume for sealed box subs to work right.
And with subs, it doesn't matter where they are or where they're pointed. In this case, the trunk cavity actually works like a 2nd speaker box. I get pretty good base response outta this setup.
