Custom designed clutch arm for v6spider..
- v6spider
Re: Custom designed clutch arm for v6spider..
Here's the finished clutch arm.. I installed it yesterday and it works beautifully!
http://www.v6spider.com
- v6spider
Back in the saddle again!
Cheers!
Rob
Cheers!
Rob
Fantastic!!
Nice work Rob!
Now, I wish there were some roads around here like you guys talk about! I can go dead straight and flat in 180 degrees of the compass for at least 2 hours before I hit a curve needing any attention! Jealous I am!!!
Nice work Rob!
- v6spider
Washington is quite mountainous on the coastal side. The eastern side has more flatter areas although the Columbia river gorge is similar to the grand canyon.SoFlaFiat wrote:Fantastic!!
Nice work Rob!
Cheers!
Rob
- Your car is a: Fiat 124 spider 1976
- divace73
good stuff, I really like how you have kept everything under the bonnet (hood), real neatv6spider wrote:Back in the saddle again!
Cheers!
Rob
We need some audio....
Cheers David
see my >>You tube channel<<
- v6spider
Is this the Oregon Coast? Looks like Chuckanut Drive!
- v6spider
Here's a video... audio is so so..divace73 wrote: good stuff, I really like how you have kept everything under the bonnet (hood), real neat
https://youtu.be/7mD-vUBLk8w
Cheers!
Rob
Nice work Rob!
Check out the Motorcycle Roads web site as there are some roads of note here in Florida hidden about:
http://www.motorcycleroads.com/category.php?id=85
Would using an external slave cylinder be an option?
http://www.jegs.com/i/McLeod/673/139006 ... Id=1503743
Personally I rather despise the ridiculous cost that the internal slave cylinders added to the job of replacing the slave cylinder when they went from external to internal especially on a front wheel drive vehicle. Usually when the internal slave cylinder fails it leaks out on the clutch saturating it with oil turning what was a $30 job of rebuilding the easily accessible slave cylinder into a two day job of dropping the front suspension, removing the trans-axle, cleaning up the mess, replacing the slave cylinder and the clutch along with having to put everything back together again.
I know some folks into off roading who are a bit tired of the internal slaves built into the throwout bearings and are replacing them with external units for ease of servicing on site when away from civilization.
- v6spider
Already fixed it.. The cable system working great with that custom clutch arm I made.. Cost me $20.00.DieselSpider wrote:Would using an external slave cylinder be an option?
Cheers!
Rob
Simple is many times best. Spare cable takes up little space and is much easier to install than a slave cylinder if one fails.v6spider wrote: Already fixed it.. The cable system working great with that custom clutch arm I made.. Cost me $20.00.rock on!
Cheers!
Rob
Alot of high schools or automotive college classes have CNC mills and even laser and hydro tables.
