76 Engine Bay Wring Harness
- 76124
- Your car is a: 76 124 Spider
Anyone have a good option for cleaning up the engine bay wiring harness on a 76 Spider with all those relays mounted on the drivers side. Would love to get it all out of there but as you know it's a lot if wires. Could clean it up by just rapping them again but that may not improve things much.
Kraig
Everett, WA
76 Spider owned just shy 30 yrs and counting
69 Spider - Big truck ate it
74 Sedan special TC Auto..Died of cancer RIP
Everett, WA
- johndemar
Re: 76 Engine Bay Wring Harness
Unless you have to worry about emissions, all but 3 of those relays can be eliminated.
76 Fiat 124 Spider
One owner since July 20, 1976
Amadio Motor, Jeannette, PA
I've seen a picture where one has them mounted under the wiper cowl. Looked neat and tidy for sure.
- 76124
I was concidering under the cowl. Im planning on placing the computronix there for a super clean look on the top of the motor.
Kraig
Everett, WA
Everett, WA
The wiper cowl area is subject to rain and snow, not a good place to locate anything electrical. Move the relays to the driver side of the firewall by extending the wiring harness to the three needed relays.
carl
carl
I put my custom relay box under the drivers side cowling in a plastic box I waterproofed. It is also on a bracket that elevates it off the floor so water can drain underneath it. Of course, the only water it sees is when i wash it.
- 76124
I was going to elevate and also place in a covered box. Car has not seen rain in a decade and snow we can dream here in the NW.
Kraig
Everett, WA
Everett, WA
- Ptoneill
Mine is a 79, but here is where I placed my computronics....under the new windshield washer tank
I am hoping the spark plug wires are long enough ......
Stay Safe,
Pat
79spider
HAVE FUN!! It's a FIAT!!
ptoneill@msn.com
Pat
79spider
ptoneill@msn.com
- SLOSpider
Shorter the wires are to coil the Better. Pat I would consider moving that coil closer.
1975 124 Spider
1989 Chevy k5 Blazer
1967 GT Mustang Fastback
i have my computronix ingition mounted just to the right of your shiny box and the wires are plenty long. I ran them along the firewall to the motor
- toplessexpat
- Your car is a: 1976 Spider 1800
I installed a small watertight relay/fuse box in my '76.
A
A
- tartan18
Where did you get that fuse box and where exactly did you mount it?
Jim MacKenzie
1975 Fiat Spider
1975 Fiat Spider
- toplessexpat
It's a Bussman from Frys. Mounted on the inside of the drivers side fender, towards the front.
A
A
- Ptoneill
SLOSpider wrote:Shorter the wires are to coil the Better. Pat I would consider moving that coil closer.
I will if the plug wires Mark supplied are not long enough. I was also thinking of a way to feed the wires from the front of the intake manifold. Do you have to worry about EFI with spark plug wires?
Stay Safe,
Pat
79spider
ptoneill@msn.com
Pat
79spider
ptoneill@msn.com
