"Test Pipe" Performance Improvements?
Daniel
Re: "Test Pipe" Performance Improvements?
Post by Daniel »
RRoller Is it the cat or the springs that make the noise? a simple test would to to place some hose inside the springs
and see if it go's away.
That's a good idea. I may crawl under there today after I get sick of painting the house and see if that works. From the sound, it is clearly the springs. This is one of those things that is difficult to resolve, since it occurs while driving at high RPMs. I have been unable so far to get my son to hang over the side and take a look under there while I do that. :mrgreen:
Csaba posted a method somewhere of adding another support to the exhaust system, overall, but I am not sure where that is located. Anyone know?
Pete
bobplyler
Post by bobplyler »
When mine was rattling, it was the heat shield.
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
focodave
Post by focodave »
bobplyler wrote:When mine was rattling, it was the heat shield.
Same here. The spot welds broke on the heat shield at the front of the converter. I used a large stainless steel worm-screw hose clamp around the shield/converter to stop it from vibrating and rattling. Works like a charm.
1970 MGB GT (my other hobby)
Will check, thanks!
wizard124
Post by wizard124 »
My Fiat mechanic recommends this one: It's a Catco #65003 universal fit and CA legal. About $100 on-line.
Frog2Spider
Post by Frog2Spider »
I recently removed the Cat and replaced it with a very well made test pipe, bought from Auto Ricambie. ( $146 w/ freight )
I think it may have 'liven'ed it up a tad', but I didn't like the sound. Maybe it just doesn't fit into my age bracket.
So, if anyone is interested, make me a offer, and you can try it out for yourself. It is the 4 bolt style for later models.
PM or pro-frog@comcast.net.
Dave.
Frog2Spider
'81 - 2000 Spider
