1979 top speed
lm48
Your car is a: 1979 and 1980 spider
Re: 1979 top speed
Post by lm48 »
There is a 79 for sale on eBay and the speedo is 80 , so I believe in 79 at some point was made the switch from 80 to 140
JEEPER
Your car is a: 1979 SPIDER
Re: 1979 top speed
Post by JEEPER »
lm48 wrote:There is a 79 for sale on eBay and the speedo is 80 , so I believe in 79 at some point was made the switch from 80 to 140
Ya I have a 79 Manufactured in Oct 78 that I bought new and it has 140 MPH speedometer.
FiatBen
Re: 1979 top speed
Post by FiatBen »
Not normally one to revive an older thread, but this one caught my interest since I'm working on a '79.
Build code 11/78 and pretty sure everything is original.
Re: 1979 top speed
My 80FI has the 80mph speedo, original for sure. If you are interested, I will go get the month of manufacture from the door plate?
donm
Your car is a: 1980 spider [carb]
Re: 1979 top speed
Post by donm »
I wish my '80 had the 140mph speedo. On a lonely stretch of 128 I had my speedo pinned at 80. I'd love to pin it at 140 and see what that's like!
1979 Spider
2001Saab SW
2004 Saab Aero
SWhiteley
Your car is a: 1982 Spider 2000 Pininfarina
Re: 1979 top speed
Post by SWhiteley »
I hope there aren't people here who were complaining about their 140 speedo...if it's too much for you, I'm sure someone will do a swap for their their 80 unit. :wink:
fiat218
Re: 1979 top speed
Post by fiat218 »
They don't go 140. I guess it just for looks
phaetn
Your car is a: 1974 Fiat Spider 1800
Re: 1979 top speed
Post by phaetn »
Yes. Plus they're so fast they never stand still: they're always going 5mph indicated even when parked. ;)
My '74 has a 140mph speedo. I've had it up to 90mph once. Probably won't do that again until I've had the steering/bearings checked. Most of the time I'm tooling around somewhere between 40 and 60mph.
So what's faster? Doing 90mph on a 140mph speedo, or overclocking an 80mph gauge to get to 90? After all, perception is reality. :)
phaetn
1974 CS1
32/36 DFEV; CompuTronix ign.
9.8:1 c/r; 40/80 intake cam w/ Isky springs
Vicks' SS header & adj. cam pulleys
A/R's progressive coils, Koni Yellow dampers
205/50-15s on CD-66 style rims
Momo wheel, Corbeau seats w/ 5 pt belt
pics and HD vids
azruss
Re: 1979 top speed
Post by azruss »
My 80Fi had an 80mph speedo. I replaced the entire cluster with deep dish gages from a 70. Wanted to go retro. my deep dish speedo read about 10% high when I first installed. Within a month, it started going haywire reading up to double the actual speed. It was also making noises. I pulled out 2 other deep dish gages i had and plugged them in and they both read fine. I picked the best one and now my speedo reads accurately according to the electronic speed monitors in my neighborhood. ( I suspect they read a hair low) as I see how they match with my 2 modern cars. Still using the same cable.
paintdudeluke
Re: 1979 top speed
Post by paintdudeluke »
I've had my 81 at 5600 in 5th. The speedo was already pegged about 1/2 way through 4th. It felt like about 105-110 maybe. I just ordered a 140 for it thats supposed to be from a 79-83. Well see how well it reads. I though about just doing the 220KPH speedo just because I hate the 85r anyway.
bradartigue
Re: 1979 top speed
Post by bradartigue »
The 85 MPH speedometers aren't so bad, every time you look down it's 3/4 to 4/4 through rotation. Always going fast.
Pininfarinas (I recall) have 120 MPH speedometers. 850 Spiders have 120 MPH speedometers that work in the 124...at least in a 124 you can get close. In an 850 at 60 MPH you've exceeded the engineering limits of the chassis.
Re: 1979 top speed
Yes, and it will be a cool day in hell before I go over 85 in this 34 year old car.
michaelj
Your car is a: 1976 Spyder
Re: 1979 top speed
Post by michaelj »
Hey we have a couple spider owners in Bonita and Naples. Are you up for a cruise in sometime? Mike
paintdudeluke
Re: 1979 top speed
With my 140 speedo it says I'm at about 100 at 5k in 5th. Seems about right, I spent a lot of time between 100 and 160 on my ZX11 Ninja so I have a pretty comfortable "feel" of 3 digit speeds. It does feel like about 100 at 5k in 5th gear and they're isn't much left either, that's about tops unless I really drag it out on an endless straight, then I might tip 5600 Rs.
v6spider
Re: 1979 top speed
Post by v6spider »
paintdudeluke wrote:With my 140 speedo it says I'm at about 100 at 5k in 5th. Seems about right, I spent a lot of time between 100 and 160 on my ZX11 Ninja so I have a pretty comfortable "feel" of 3 digit speeds. It does feel like about 100 at 5k in 5th gear and they're isn't much left either, that's about tops unless I really drag it out on an endless straight, then I might tip 5600 Rs.
Speed freak! :twisted: :twisted: :twisted: :mrgreen:
Cheers!
Rob
http://www.v6spider.com
