Camshaft options
Re: Camshaft options
since the megasquirt is programmable I'd expect you could somewhat mitigate the effect of overlap. The issue with the Bosch L-Jet on the Fiat is trying to get the fuel mixture correct throughout the rpm range
- v6spider
Possibly Mark... although the cam grinder... Comp Cams explicitly didn't recommend it. I also already have a 4bbl Carter that is tuned to that cam..makes it much simpler..
Rob
Rob
http://www.v6spider.com
