Lightened Flywheel and Crank pulley
In a few months I will be converting my spider over to the Ford EDIS ignition system to compliment an upgrade to the Megasquirt computer already in the car...
...in order to get the EDIS in I have to get a crank pulley machined to fit a 36-1 sensor wheel ect ect...
The question is, since I am thinking about getting this machined out of alluminum, what should I look about for as far as engine balancing?
What are peoples experiences with lightened flywheels as wheel?
the TC motor is balanced internally, so the crank pulley isn't an issue. For spiderrey's crank fired system we modified a stock pulley, mounting the trigger wheel on the back of it.
You should read Crofts' book about flywheel lightening, too much material removal will result in a much-shortened life.
- Site Admin
Guy's book
Mark -
I have Guy's book as well as another spider specific book, can't remember the name of the other book off-hand. Guy's book is outstanding. He used to come in here from time to time. Maybe he will show up again. I think before anyone posts any portions of his book online though, they should get Guy's permission to do so. Wouldn't want to offend him, but even more important I wouldn't want to have any copyright issues.
=e=
=e=
Founder & Owner
FiatSpider.com
FiatSpider.com
I've hacked out quite a bit of material from the stock flywheels, they are plenty safe with >12mm thickness. Don't take any more from the stock flywheel though. Here is a link to a file on my site with different comparisons as far as lightened flywheels.
http://www.millersmule.com/File%20Libra ... arison.pdf
Have a look to learn more
Happy motoring,
-Jason Miller
Happy motoring,
-Jason Miller
- 124JOE
Re: Lightened Flywheel and Crank pulley
im thinking on this subject
- maytag
Re:
I don't really see the down-side to this.Hjulen wrote:Since the primary job of the flywheel is to "store" inertia or smooth out the revs, if too much of the flywheel weight is removed it could cause fast "dereving of the engine" and make street driving a little more finicky.
What IS a factor that should be considered is the ramifications to the potential engine-braking, or compression-braking.
But all-in-all, I've never heard of anyone lightening their flywheel and then wishing they hadn't.
- 124JOE
i have a flywheel in the garage
not sure it will fit
a buddy took one look and said"junk"
but again im not sure of that ether
Re:
Are you sure about this? I've seen several crank pulleys off Spiders, and they all have varying numbers of 5mm drilled depressions on the back side of the innermost pulley. Sure looks like a factory balancing technique.So Cal Mark wrote:the TC motor is balanced internally, so the crank pulley isn't an issue...
