Okay, I've come across the first disappointment with this 81 FI since buying it cheap a month ago. I finally got the entire interior stripped out and it is clear that it was left wet after the top down in rain. The bottoms of both seats are 50% rust flake and the back seat wire frame is rusty but okay. That would be fine, but the rear floor pans (the short section behind the seat channel) is rusted right through where it meets the longitudinal channels (sills). I've poked and brushed thoroughly and it is isolated to that narrow bit between the longitudinal and the outside seat support, roughly an inch wide by a foot in length. Water was obviously sitting in that spot over a long period. This is on both sides of the car, if I did not make that clear already.
So do I replace the entire rear floor pans or can I have this narrow section replaced? The floor pans I see online are simply flat panels cut and bent to shape, so I'm thinking they are more expense than I need/can afford at this time. My neighbor is a great welder and can probably repair this narrow bit (after I remove the fuel lines on the driver's side). Of course the outside seat support makes a very tight fit. So that would have to come off.
Does anyone know if these floorpans and seat supports are continuous welds or spot welds? Can I remove them with judicious spot weld drilling?
Just looking for suggestions. Morale remains high.
