I now have lightweight flywheels in stock. Billet aluminum with a replaceable steel insert. They fit 1800 and 2.0L motors
Weight is 8.5 lbs compared to 13.9 lbs for the stock flywheel. The flywheel includes a steel bolt plate to prevent any damage to the aluminum when torqueing the bolts.
$399, $18 shipping in the US
Lightweight flywheel
Re: Lightweight flywheel
Isn't the stock weight of the 2L and 1800 flywheel around 22 lbs?So Cal Mark wrote:I now have lightweight flywheels in stock. Billet aluminum with a replaceable steel insert. They fit 1800 and 2.0L motors
Does this flywheel include a ring gear or do we need to provide 1?
So Cal Mark wrote:all of them that I weighed were about 14 lbs
Mark you may want to update your factory weight listings on the 1800 & 2L flywheel they are around 21 to 22 lbs just
thought I let you know not that it matters.
