What have I done?!
- Your car is a: 1975 Spider
Re: What have I done?!
honestly, if it was in my shop, i would weld tot he top of it with my mig welder, then grab the piece i create and unscrew the bolt. some people went a nut and then remove it with a wrench. but i prefer just welding to the bolt and using vise grips. i get better penetration with the welds that way
son has 78 spider
son has 78 spider
- rjkoop
Yep. Don't have access to a welder but this may be a last resort. I've read a bit and a masonary bit with cutting oil might help. I'll try a smaller one to ensure I don't get near the threads. The hardened screw extractor is in the middle so I'm hoping the bit, once started, might catch the extractor and screw it out (because turning it clockwise will remove it). Then I'm back to the original broken off bolt which I think I can get out with progressively larger bits.BEEK wrote:honestly, if it was in my shop, i would weld tot he top of it with my mig welder, then grab the piece i create and unscrew the bolt. some people went a nut and then remove it with a wrench. but i prefer just welding to the bolt and using vise grips. i get better penetration with the welds that way
Richard
1981 Fiat Spider
Ottawa, Canada
1981 Fiat Spider
Ottawa, Canada
If it were me, I would do as beek suggested. I have done this a few times with success. If you don't have a welding machine find a buddy that does. A wire welder works great. When you start trying to drill the extractor and the stud it can lead to other problems. When I bought my car the p o had broken a bolt for the alt bracket and an extractor in it. He had already started drilling it out. He got off center and got into the block. After 8 hours in a buddy's machine shop and 3 high dollar carbide bits , I finally was able to get it out. Along with repairing the bolt hole and taping to a larger size. If I had as much of the bolt exposed as you have, 2 hour job at the most with problems.
Dennis Modisette
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
- rjkoop
Anybody in the Ottawa area have a MIG welder I could borrow for an evening/weekend? Or someone who could help get that EZ Out out? (there's a case of beer in it for you!) I want to try the weld a nut to the broken off bolt. Drilling's going nowhere fast!
I tried breaking apart the EZ Out (never using EZ Outs again!) but very little progress. Otherwise I'll head out to Home Depot and hope the MIG welding thing works.
Richard
1981 Fiat Spider
Ottawa, Canada
1981 Fiat Spider
Ottawa, Canada
Richard I do have a mig but I'm out of argon/co2 mix right now.
I hope to get a fresh tank this week if time permits.
Andre
Andre
- rjkoop
Andre,Andre124 wrote:Richard I do have a mig but I'm out of argon/co2 mix right now.
Andre
I'd pay you for the fill for sure. To do my interior I rented a MIG welder from Home Depot but I didn't use gas. I used the flux wire. Wasn't really impressed with the unit or the results. That being said I was new to welding. Hopefully this nut trick is pretty easy to do. I'm still looking for a specialized drill bit but came up empty at places like Home Depot and Lowes.
Richard
Richard
1981 Fiat Spider
Ottawa, Canada
1981 Fiat Spider
Ottawa, Canada
I found my carbide bits at a machine shop supply store. Bits were pricey but effective. I'm thinking the carbide bits at the Home Depot and lowes are just carbide tipped. Good luck on getting the head bolt out.
Dennis Modisette
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
Yeah those easy outs are crap.
Had one break off in my cailper on the British sport car. Grrr.
- rjkoop
Didn't realize you could get carbide bit vs. carbide tipped. The ones from Home Depot were definitely only carbide tipped. I'll call around Ottawa (more at the specialty tool stores or maybe Sears) and see what I can find.dmwhiteoak wrote:I found my carbide bits at a machine shop supply store. Bits were pricey but effective. I'm thinking the carbide bits at the Home Depot and lowes are just carbide tipped. Good luck on getting the head bolt out.
Thanks.
Richard
1981 Fiat Spider
Ottawa, Canada
1981 Fiat Spider
Ottawa, Canada
I get my special carbide bits from McMastercarr about 35.00 each and can usually drill out just 2 or 3 broken taps with them.
1987 Lotus Super 7 clone
1981 Fiat Spider 2000 AT
1982 Fiat Spider 2000 5sd
1970 Fiat Coupe
1970 Fiat Coupe
- rjkoop
So drilling through a EZ out is next to impossible. 3 carbide drill bits later and only about 1/4" of material removed. I also tried the hit it and it should fracture but that didn't do anything. So I drilled small holes around the EZ out and I'm going to extract it that way. The block threads will probably be ruined so I'm looking to retap. I saw these.
http://www.timesert.com/
Looks much better than helicoil. Other option is that I tow it to a machinist and they refill and retap. Thoughts?
Richard
1981 Fiat Spider
Ottawa, Canada
1981 Fiat Spider
Ottawa, Canada
Masonry bit? To drill out metal,ain't going to work,the end will bust offrjkoop wrote:Yep. Don't have access to a welder but this may be a last resort. I've read a bit and a masonary bit with cutting oil might help. I'll try a smaller one to ensure I don't get near the threads. The hardened screw extractor is in the middle so I'm hoping the bit, once started, might catch the extractor and screw it out (because turning it clockwise will remove it). Then I'm back to the original broken off bolt which I think I can get out with progressively larger bits.BEEK wrote:honestly, if it was in my shop, i would weld tot he top of it with my mig welder, then grab the piece i create and unscrew the bolt. some people went a nut and then remove it with a wrench. but i prefer just welding to the bolt and using vise grips. i get better penetration with the welds that way
- rjkoop
Yep. Didn't work. I've decided to retap. I mentioned this later on in the thread.fiat218 wrote:Masonry bit? To drill out metal,ain't going to work,the end will bust offrjkoop wrote:Yep. Don't have access to a welder but this may be a last resort. I've read a bit and a masonary bit with cutting oil might help. I'll try a smaller one to ensure I don't get near the threads. The hardened screw extractor is in the middle so I'm hoping the bit, once started, might catch the extractor and screw it out (because turning it clockwise will remove it). Then I'm back to the original broken off bolt which I think I can get out with progressively larger bits.BEEK wrote:honestly, if it was in my shop, i would weld tot he top of it with my mig welder, then grab the piece i create and unscrew the bolt. some people went a nut and then remove it with a wrench. but i prefer just welding to the bolt and using vise grips. i get better penetration with the welds that way
Richard
1981 Fiat Spider
Ottawa, Canada
1981 Fiat Spider
Ottawa, Canada
what didnt work? did the welded area break off or did the bolt break again lower?
son has 78 spider
son has 78 spider
Welding to the bolt works.... try it you'll like it !!!!
Might take a bit of leg work on your behalf. if you have an electric dryer outlet, one can source a plug adapter that will work with the welder plug and a 140 or 180 type mig welder will work just great and the broken bolt will just unscrew .
have to find a person with the welder as well... bit of leg work but you will not be disappointed with the results.
http://www.fiatspider.com/f08/viewtopic ... ck#p165926
About half way down are a few pics.
Chris
Chris
