Fall/Winter/Spring Projects 2012/13 for Fiona RESOLVED
redcars
Re: Fall/Winter/Spring Projects for Fiona
Post by redcars »
For the inside of the coolant jug put in coffee grounds and some water and start shaking. Cleans resivors real good. for the outside cleaner of your choice.
1987 Lotus Super 7 clone
1981 Fiat Spider 2000 AT
1982 Fiat Spider 2000 5sd
1970 Fiat Coupe
It seems as if the oil stains, etc are so embedded in the plastic that nothing will bring them out, but I guess I haven't really had a go at it yet. It is on the endlessly long list....
4uall
Post by 4uall »
Check what this guy did :shock:
I read up a few places online (mainly euro-restoration sites) and came to a few conclusions...some people use sand, some use coffee,I decided to try cat litter twisted
so i dumped about a cup of kitty litter in the resov and sprayed the inside with a bunch of brake cleaner. shook it for abut 2 minutes and voila! super clean inside!
A little acetone/heavy cleaner on the outside and it's nice and clean.
http://rivperformance.editboard.com/t67 ... -reservoir
seems like it is the brake cleaner action that does the chemical chore, with the added abrasion of the kitty litter, sand, etc. I will have to try this. Not wild about handling acetone though for the exterior, wish there was something more benign to use.
4uall
Post by 4uall »
I had seen vinegar however, it is acidic and I do not want that near my system etc. We are going away for the weekend so I will keep you posted next week with any progress (photos as always). :wink:
narfire
Post by narfire »
I've used a couple of tbls of Cascade dish washer soap over night with hot water and in the morning the inside came out great. Outside, brake cleaner and scouring pad cleaned it up pretty good.
Thanks, I will try that!
Pete
4uall
Post by 4uall »
A week & one day later look what arrives :wink: Heading out to the garage right now to start the process. I'll keep you posted
Matt @ Vicks Autosport sent me the correct bushings
Looks like there may be a way to grease these in the future
Not sure I am willing to promote VAS at this time.
4uall
Post by 4uall »
Was too frustrated to post on this yesterday :x The bottom fit as it should however, when it came to putting in the upper OMFG! Here we go again :roll: The holes all lined up as they should when it was out yet, when I went to put it in the upper control arm arrrrrrrrrrgh they would not fit or line up. Fast forward 4 hrs and I found a way for it to fit and will hopefully be completing the front suspension and new brake line this week in time for the long weekend :wink:
Photos to come later :mrgreen:
Weelan
Post by Weelan »
Dang man, you're having so much trouble with these suspension parts! So sorry to hear it... Just keep telling yourself how worth it it will be after it's done.
4uall
Post by 4uall »
Providing they work out okay :shock: Ironically, I was looking at their rads which are only $199.00
4uall
Post by 4uall »
:x WOW I am being punished for sure :x
Made it work VAS be damned
Did not paint coil due to weather
Seriously! Who the FAWK designed this failure?
In an attempt to save my last Koni I used what was supplied until this happened WTF?
Went back and used what was originally supplied
All done, just need to clean, add wheel, brake line and sway bar
Going to the gym to burn off the frustration :evil:
4uall
Post by 4uall »
Had some free time today, had to re-do the brakes (small leak with the new washers) tightened enough to compress the brass/copper washers. Installed the wheel, torqued the upper pivot bolt & lower control arm bushings under load :wink:
Now when it came to re-installing the stock front sway bar some issues came up :shock: The first (this should come as no surprise with my current issues) was the lower control arm had a missing bolt
Then (for the life of me) I could not get my sway bar to fit properly with the new bushings installed :x
Does anyone know if it would be okay to leave the sway bar off to drive it to an alignment shop? I'll get them to give it a try :roll:
If anyone is in the Ottawa area I would love some help/advice as this is all I need to get Fiona on the road for this season
lanciahf
Post by lanciahf »
Jay try this,
Loosely mount the sway bar to the center mounts then put a jack under the lower control arm. Jack up the lower control arm to align the bar to the arm and try to slip the bracket on. Use a pair of channel locks to "squeeze" the bracket to the arm. You should be able to get the bracket close enough to the arm to start the nuts.
Yes I know a royal pain in the ass....
Online
wizard124
Post by wizard124 »
Jay:
I came across your post. I want to alert you to a possible installation mistake :!: :!: :!:
I am not an expert but I was very careful when removing the factory balljoints and took pictures:
This picture shows the bottom side of the upper control arm. The base outline of the old ballpoint is plainly visible. The lower BJ also mounts to the bottom of the lower arm. You have yours mounted to the upper side :shock:
With the weight of the car on its wheels, that balljoint is trying to be pushed out (held by 3 bolts) rather than pushed against the arm. A close look at a picture in my workshop manual confirms this. Go here: https://www.autoricambi.us/product/SU3- ... ...another confirmation :!: :!:
A PITA to change it, but probably critical that you do!!
Warren
[quote="4uall"]:x WOW I am being punished for sure :x
