performance cams
performance cams
Wants ask about the performance cams. When you install the 43mm intake valve , and the d 37.5mm exhaust valve do you have too add more shims ?
Re: performance cams
sometimes yes, sometimes no. It all depends how deep the valves are put into the seats, the cam lift, etc
So Cal Mark wrote:sometimes yes, sometimes no. It all depends how deep the valves are put into the seats, the cam lift, etc
could you grind a little off the vale to make up how far the vale seats in the head?
- Your car is a: 1975 Spider
Rodman, I have thousands of shims right up the road from you. i really suggest you come by one day.
son has 78 spider
son has 78 spider
You could if you are out of shim-range. But it's best if it's done by a machine shop, so you get a perfectly straight surface.
But a little would be about half a millimeter or so, not much more than that.
would you happen to know the spec on the stock cams?vandor wrote:>could you grind a little off the vale to make up how far the vale seats in the head?
Which specs? Timing is 5-55, 55-5 at the large clearance that Fiat used to measure valve timing.
I don't know what it would be at running clearances.
(off the top of my head) the lift is 9.3mm
- FiatMac
I just measured a stock cam profile. Lift was measured at the cam follower. Gross lift was 9.55mm. Corrected for .018" lash (0.4572mm)the lift is 9.0932. At this lash the timing looks to be 30/70, 70/30 @ 110 lobe center. If I plug 0.050" lash into my spreadsheet, then I get 5/55, 55/5 (within the measurement error) as Csaba stated above.
Stan McConnell
Retired Mechanical Engineer
Salisbury, North Carolina
82 2000 Spider (driving)
83 parts car
83 parts car
