1800 head
FiatMac
Re: 1800 head
Post by FiatMac »
wmausbach wrote:FiatMAc,
The PBS article was written based on their experience (Calf.). The 1585 was never imported hence the brothers never saw one. I used to talk to Paul quite a bit when I was racing. Like Steve noted that engine was used extensively in the 80's and 90's. At that point PBS was not in the development mode for the 124 engine.
Ciao
Wayne
Wayne,
I agree, I was only speaking for US versions which were limited. I think we are getting to the same point. Based on Steve's comments the 1585 has the same bore spacing as the 1592, 1795, and 1995 cc engines which means the combustion chambers in the head are offset. The only engines with the combustion chambers in the head centered over the bore are the 1492 and 1608cc. Correct?
So, if it were available, the 1585 head with 43.5mm inlet valves would be a good way to go.
Stan McConnell
Retired Mechanical Engineer
Salisbury, North Carolina
82 2000 Spider (driving)
83 parts car
124JOE
Re: 1800 head
Post by 124JOE »
beek it looks like from the pics you should use the 1592 gasket
wmausbach
Your car is a: fiat 124 spider
Re: 1800 head
Post by wmausbach »
Fiat Mac, Correct.
I think the point of the original question was if going to a later madel head would be good. In my opinion (and many others) he should use the original head with maybe the 43.5 valves. If he could get a 1585 head if would be worth it for development however for a street engine it is hard to beat the OEM for the 1608.
Ciao
Wayne
fiat218
Re: 1800 head
Post by fiat218 »
in replacing the intake and carb. do i have a gasket between the space. one on the intake and then the spacer then do i have another gasket on the top of the spacer and then the carb?
124JOE
Re: 1800 head
Post by 124JOE »
yes matt sent me 2 gaskets
one for the intake then the spacer
then one ontop of the spacer
then the carb
