1983 fuse block wiring
wbsterritt
Post by wbsterritt »
Can someone tell me if there is a difference in the wiring for the '83 "Pinin" fuse block from that of the '82 schematic that I have? Particularly, the wire colors vary in some ways from each other and it's a real PITA trying to troubleshoot the circuits. The previous owner added some circuits (radio/system?) to the fuse block and now I'm wondering if they may have switched some of the wires around in the process. The '82 schematic is the most recent and only one that I can find.
wbsterritt
Re: 1983 fuse block wiring
The short answer to the question is "yes." One circuit in particular is the power windows switch circuit. Both switches feed off of a 16 amp fuse at "A" and not "L" & "M" as in the case with '82's and prior. Quite a few other differences also. FYI
