Turn signal not working correctly
Flyingthere
Post by Flyingthere »
I have found an issue with my front right turn signal. With the marker lights and or headlights on I am finding the right front is not flashing correctly. What I mean by correctly the marker light stays on and the turnsignal (second filiment lights) becomes brighter. The left and rear turn signals are working correctly, When I found the problem the signal was not doing anything. I replaced the flasher and it started flashing like it is now. In addition I checked the wiring and believe it is connected correctly.
Any suggestions?
mbouse
Re: Turn signal not working correctly
Post by mbouse »
#1, look for and find the grounding pod on the inside fender, near the front. looks like a bottle cap, or a crown.
clean and tighten all the grounds.
then if you are still having issues, remove the lens, remove the bulb and clean the socket. replace the bulb with a new bulb.
katsi
Post by katsi »
When I was working throught the lighting system, I too found that the ground connections were weak. Making a better ground made everything work as it should. Unfortunatly, it took me about a week to figure it out. :mrgreen:
definitely a ground issue
Flyingthere
Thanks guys, I have not had a chance to look at it but I think your correct it has to be a ground issue. I will work on it this next weekend and let you know.
