Courtesy Light
blanchardkeith
Courtesy Light
Post by blanchardkeith »
Just got a new light that goes under the radio. Haven't had one in over 20 years. Here is my ingnorance. I thought you could just hook up to a hot and ground and flick......it would work. Doesn't work in any way shape or form. The old original wires are long gone. But i do have a hot and a ground. Help! What goes where.....
in the dark........
pope
Re: Courtesy Light
Post by pope »
Hey Keith,
The courtesy light has three prongs for wires. One is a hot lead, one is normal ground and one is a ground from the door switches. Assuming that your hot is hot and your ground is good, and the bulb is not blown, you should be able to get it to switch on if you hook it up correctly only using the hot and ground. Of course it will not go on when the doors open unless you hook up the third wire.
mbouse
Re: Courtesy Light
Post by mbouse »
you should have a red/black a black and a purple wire.
