Interior rear view mirror
PeterParker
Post by PeterParker »
How do you remove the interior rear view mirror on a 79 Spider? I see no screws or anything else that keeps the mirror attached to the car. Thanks in advance.
wizard124
Re: Interior rear view mirror
Post by wizard124 »
Pull on it. Springs fit over a ball mount.
PaulRandall
Your car is a: 1980 Fiat 2000
Post by PaulRandall »
On the bottom of the mount where it is against the window frame, there is a small opening. Stick a screw driver in there and twist it, or pry it. The mirror is held on to the plate beneath by a spring/snap ring. Be careful to try to not break the plastic.
Paul
PeterParker
Thanks gentlemen. Have the mirror off and ready to reinstall. Hopefully it goes back on as easily as it came off.
