Car not cranking
- Your car is a: 1980 Fiat Spider 2000
Car not cranking
Well my 1980 Fiat Spider carbureted decided to not crank. It was perfectly fine I had driven it earlier in the day. Tried it later and all the electricity works and I could hear 1 click from the relay when I turned the key, but it wouldn’t crank. It’s been like this for 4 days and still nothing. Any ideas?
Re: Car not cranking
I just had a similar experience with my 78. It was the ignition switch. I pushed on the wires going to the terminals, and suddenly had power.
I'd check the usual stuff first:
- Check/clean battery terminals
- Check battery voltage when attempting to crank
- Charge the battery or try cranking while getting jumped by another car
- Add a ground from engine to frame
If the click is coming from the starter solenoid, then it is not the ignition switch.
Ok thanks y’all. I’ll try these things.
IS this problem resolved???
