Hi at all,
in 2019 I already asked you about the amount of built Spider, wheather the 200,000th car was built or not.
In order to get to the bottom of the matter and to approach the true production number, the worldwide Spider Register can be used. To do this, it is important to know that FIAT has performed sequential numbering across types. The BS/BS1 Spiders follow directly to the AS, the CS/CS1/CSA directly or even overlap to the BS1 etc. However, there are gaps in numbering (e.g. for a new manufacture year).
In order to limit these gaps, the vehicle identification, chassis or serial numbers in the Register, which now includes more than 19,300 vehicles, were evaluated in increments of 100. Some gaps seem to exist, many of which are probably due to a lack of documented vehicles.
Hereby I need your help: Who owns or knows vehicles or has documents about vehicles that can close the gaps? Any hint on this is welcome! Please contact: fahrzeugregister@fiatspider.de or directly via the website at:
The current gaps in vehicle identification numbers between known numbers (presumably official gaps in bold). Filled in gaps since 2019 were deleted:
124AS00086xx (0008553 – 0008752)
124AS00103xx (0010250 – 0010461)
124AS00109xx (0010879 – 0011042)
124AS00112xx (0011179 – 0011322)
124AS00115xx (0011446 – 0011638)
124AS00119xx (0011824 – 0012020)
124AS00176xx (0017501 – 0017712)
124AS00179xx (0017890 – 0018075)
124BS00252xx (0025187 – 0025391)
124BS(1)00277xx (0027684 – 0027830)
124BS(1)00306xx (003058x – 0030723)
124BS(1)00312xx (0031174 – 0031302)
124BS(1)00329xx (0032810 – 0033064)
124BS100507xx (0050617 – 0050835)
124BS100509xx (0050835 – 0051052)
124BS100514xx (0051382 – 0051555)
124BS100518xx (0051763 – 0051950)
124BS100563xx (0056263 – 0056422)
124CS/CSA00644xx (0064397 – 0064642)
124CS00684xx (0068331 - 0068504)
124CS100745xx (0074481 – 0074613)
124CS100755xx (0075498 – 0075640)
124CS100762xx (0076194 – 0076376)
124CS100842xx (0084199 – 0084317)
124CS100848xx (0084796 – 0085053)
124CS100849xx
124CS100893xx (0089284 – 0089412)
124CS100896xx (0089517 – 0089786)
124CS101253xx (0125236 – 0125920)
124CS101254xx
124CS101255xx
124CS101256xx
124CS101257xx
124CS101258xx:
124CS101421xx (0142014 - 0142504)
124CS101422xx
124CS101423xx
124CS101424xx
124CS201635xx (0163449 - 0164014)
124CS201636xx
124CS201637xx
124CS201638xx
124CS201639xx
ZFA 124CS081875xx (8187479 – 8188001)
ZFA 124CS081876xx
ZFA 124CS081877xx
ZFA 124CS081878xx
ZFA 124CS081879xx
ZFA124CS081892xx (0189261 – 5000001)
ZFA124CS081893xx
ZFA124CS081894xx
ZFA124CS0050041xx (5004034 – 5500004)
ZFA124CS0050042xx
ZFA124CS0050043xx
ZFR124DS0055037xx (5503627 – 5504001)
ZFR124DS0055038xx
ZFR124DS0055039xx
ZFR124DS0055064xx (5506352 – 5510003)
ZFR124DS0055065xx
ZFR124DS0055066xx
Last known identification number: ZFR124DS005511940
I am curious to see if we can close the gaps and thus confirm that FIAT has produced more than 200,000 vehicles.
Cheers Ralf
2nd try - amount of built Fiat 124 Spider
- Your car is a: 69 AS Spider
69 AS Spider
the Worldwide Spider Register
