Where to find a spare tire
peteshack
Your car is a: 1977 124 Spider
Post by peteshack »
Anybody know where I can buy a spare tire for my 1977 124 spider?
I would prefer a small donut type tire that will fit in the trunk.
I currently have 15" tires, but I could use a 13" as a spare or do I need to find a 15" spare?
Thanks for your help!
redcars
Re: Where to find a spare tire
Post by redcars »
First do you have a 13" rim. If so you can get tires at tireeasy.com they have a nice selection. I like the Achilles tires. I have them on 2 of my cars. The size that is closest to original diameter is 185/70 13. This size fits in the truck.
1987 Lotus Super 7 clone
1981 Fiat Spider 2000 AT
1982 Fiat Spider 2000 5sd
1970 Fiat Coupe
ORFORD2004
Post by ORFORD2004 »
I put one from Fiat 500 and use it in front only. No rubbing
peteshack
Post by peteshack »
Actually I need the whole wheel, not just the tire.
So if I have a flat, Is it ok to use a 13" spare if the rest of the wheels are 15"?
TheBender
Patron 2019
Patron 2019
Your car is a: 1978 124 Spider
Post by TheBender »
peteshack wrote:Actually I need the whole wheel, not just the tire.
It should be fine to use a 13” as a spare. The circumference should be very similar if you size the 15” correctly. The 13 fits perfectly in the trunk of course. I just put a 15 in my trunk and it fits fine too. It’s slightly taller so the board cover pops up slightly but I’ll be able to trim that out easily enough.
greenspider
Your car is a: 1980 Spider 2000 FI manual
Post by greenspider »
Check with Midwest-Bayless.
peteshack
Post by peteshack »
Yep, Midwest-Bayless has them!
https://www.midwest-bayless.com/p-23100 ... on-u8.aspx
Thanks All
TheBender
Patron 2019
Patron 2019
Post by TheBender »
Here’s my 15” in the trunk. Had to put the wheel in with the inner side up and use a wedge to pin it in place. Clears my fuel pump.
TheBender
Patron 2019
Patron 2019
Post by TheBender »
I now have a 13” spare available with a new tire on it. I’m in Texas.
