LED Headlights ?
cabanabob
Patron 2021
Patron 2021
Your car is a: 1975 Fiat Spider And 1977 Fiat Spider
LED Headlights ?
Post by cabanabob »
Looking for help to install the Midwest Bayless LED Headlights---"Headlight Bulb SET 2x - 7" H4 L.E.D. LED Headlight KIT - Fiat Lancia All w/7" Bulb - NEW" The description shows a need to cut holes in the housing to dissipate heat, but outside of that---what else needs to be done? how do they connect to the original wiring, etc? Is there a downside? Upside? thanks.
TheBender
Patron 2019
Patron 2019
Your car is a: 1978 124 Spider
Re: LED Headlights ?
Post by TheBender »
I installed them a few years ago. Pretty much plug and play. Very easy and straight forward. They are fantastic.
Hootch
Post by Hootch »
Hi Cabanabob,
I just picked up the same kit and it's next on my list. Were you able to install, and do you have any tips or gotchas I should be aware of? Did you drill the holes, as Mid-West Bayless recommends, and did you add relays or change any wiring (I'm told that's not needed, but just wondering)
Lastly, did you see a big difference in headlight performance?
I'm putting these into a '78 spider and I'm excited to be able to see the road! :-)
Thanks!
Hootch McGee
1978 124 Spider (1592 cc motor)
2012 Mini Cooper Clubman S
2004 Aprilia Mojito
TheBender
Patron 2019
Patron 2019
Post by TheBender »
Hootch wrote:Hi Cabanabob,
Thanks!
Very easy install. I drilled some holes and I know people that didn’t. No issues for either way. They are a Tremendous update and you’re going to be very happy. You’ll want to adjust the headlights after install and the. The hardest part is getting the gasket and rings back on. Very easy amd straight forward stuff.
Hootch
Post by Hootch »
Thanks for the reply, and I'm glad it proved to be a worthwhile endeavor. I have some stripped screws to content with first, but looking forward to making the upgrade.
Hootch McGee
2004 Aprilia Mojito
