Hood Pad Adhesive/install
mumbo
Your car is a: 1977 1978 124
Post by mumbo »
I just bought the new hood pad set for my 77 from Auto Ricambi. Anybody have any tips fopr installing it? It is quite a bit oversized and will have to trim it. Is 3M spray adhesive good enough for the heat? I will tuck it in under the Sheetmetal lip as good as I can . Has anybody found a welting type trim that can go on that sheet metal edge that can trim it out ?
Integrale
Your car is a: 1980 Spider
Re: Hood Pad Adhesive/install
Post by Integrale »
If you are concerned about heat you could try something like this:
https://www.eastwood.com/dei-hi-temp-sp ... gle&wv=3.1
