I just discovered this in an old medieval manuscript. Should have guessed Dante had more to say.
L'undicesimo Cerchio:
Oltre i reami congelati dell'anello di Satana è il livello successivo. Nell'oscurità più assoluta una fragile forma umana lotta. Infinitamente è coperto dagli escrementi di Satana; Alla fine è costretto a provare a mettere le parti in posti troppo piccoli. Il suo peccato? Ha progettato il compensatore del freno FIAT.
- Your car is a: 1981 Spider
Re: L'undicesimo Cerchio
OK, I'll bite. Didn't Dante have nine levels, as such:
1) bleeding the brakes
2) replacing the heater core
3) replacing a clutch cable
4) totally filling the cooling system
5) electrical grounds
6) relays (see #5 above)
7) vacuum leaks in the intake
8 ) replacing a brake booster
9) removing a transmission that is too large for the transmission tunnel?
And my favorite: Previous Owners who did all sorts of, errr, uncalled for things.
Exactly, Bryan.
Somehow the levels just go further and further down. It really is like hell: just when you think you are past the worst of it all...
I have gone through each and every one of these levels and will be returning to the 9th this week.18Fiatsandcounting wrote:OK, I'll bite. Didn't Dante have nine levels, as such:
Why, you ask? Because I found a gentleman on craigslist who rebuilds fiat 124 transmissions for $500 a pop. And he'll give you a discount if you return a core. Of which I have two, one full of new parts that he can use.
I bought fender covers for the fresh paint and a transmission lift thingy to make this not such a nightmare this time. Wonder if I can yank it out in in less than 3 hours...
- aj81spider
I had to use Google translate (turns out owning an Italian car doesn't mean you speak Italian - who knew?) - That's hilarious.
A.J.
2006 Corvette
2006 Corvette
I will have to confess: I do not speak Italian. I do, however, fluently speak Google.
