124 Spider BS1 glove box lock
nicks
Your car is a: 1972 FIAT 124 Sport Spider BS1 1608cc
Post by nicks »
Hi
I've given up finding an affordable (less than $70 / £50 / €50) replacement for my broken lock so wondering if anyone has discovered an alternative that could be persuaded to fit ? For example, from Alfa's, other FIAT's, MG's, Triumphs, Porches, Jag's.
Nick
Re: 124 Spider BS1 glove box lock
I don't have an alternative lock solution for you, but here's one possibility:
https://www.midwest-bayless.com/p-8806- ... 85-u8.aspx
Not sure what the shipping costs would be, though. And there is no key although you might be able to substitute the tumbler core from your existing lock. Or live without a way to lock the glovebox.
PaulC
Patron 2022
Patron 2022
Post by PaulC »
When we replaced the dash with a California style dash the glove box disappeared so I think I still have the box lid and lock squirreled away somewhere.
You'd still need to replace the lock tumbler.
DieselSpider
Post by DieselSpider »
Whats broken about it? With most its just the plastic hook which breaks and many times can be restored with the guitar repairman's trick of Super Glue and Baking Soda. A new hook can also be made from a block of plastic or aluminum using a dremel tool/die grinder.
