1985.5 azzurra instrument cluster circuit
Nikkum
Your car is a: 1985 pininfarina
Post by Nikkum »
I have a short on 8amp fuse 2. Instrument cluster illumination doesnt work. Circuitry behind dials fine. Small removal harness behind cluster fine. So must be in v difficult bound wires or peripheral like lights. Before randomly checking every light etc.!! Does anyone have accurate info on which things are on same circuit as instrument illumination lights on a 1985? Grateful as ever.
davery
Your car is a: 1985 Spider
Re: 1985.5 azzurra instrument cluster circuit
Post by davery »
Nikkum wrote:I have a short on 8amp fuse 2. Instrument cluster illumination doesnt work. Circuitry behind dials fine. Small removal harness behind cluster fine. So must be in v difficult bound wires or peripheral like lights. Before randomly checking every light etc.!! Does anyone have accurate info on which things are on same circuit as instrument illumination lights on a 1985? Grateful as ever.
I'm not I have seen a separate wiring diagram for an 85.5. Do you have the wiring diagram for the 83-85? On the 84 diagram I have it looks like circuit 2 is an 8A fuse and includes the ignition switch, cigarette lighter, trunk opener relay, and (through an inline fuse) radio. I think the lights on the instrument cluster go through more than one circuit. Do part of the cluster lights work or nothing at all?
Don Avery
Dayton, OH/Sarasota,FL
1985 Pininfarina
2011 Eos
2012 Mercedes E550 Cabriolet
It would be good to know the history of you problems.
I think you have 2 separate issues. The 1985 owners manual shows Fuse 2 is for the Cigar lighter and the trunk electric latch. If it is blowing I would begin looking at those circuits.
The instrument cluster lights are shown to be on fuse 8.
Have you checked for voltage at the dash light dinner control???
Nikkum
Post by Nikkum »
I'll check these out tomorrow and tx. Where is the dimmer control? I have read the rheostat can be a problem but can't find it!!
Nikkum
Post by Nikkum »
Just the illumination. All the instruments work fine.
Nikkum
Post by Nikkum »
Boris61
Post by Boris61 »
On 84 dimmer is on horizontal mounted wheel directly above window switches and between vents.
ekstrandt
Patron 2019
Patron 2019
Your car is a: 1985.5 pininfarina
Post by ekstrandt »
Brad Artigue was hosting a copy of my manual on his site. It is something you will want to get a hold of.
