Temporary Horn Button or No Driving
Nitrate
Your car is a: 1981 Fiat 2000
Post by Nitrate »
1981,2000. I need to setup a temporary horn button. I can get a switch from the auto store but I am at a loss on the wiring end of things. I think there are two wires involved a Violet/Black and a Gray/Black. I'm grounded until I can get the horn working. Can someone walk me thru this? Electric work is not my strong suit. Thanks RB
Nitrate
Re: Temporary Horn Button or No Driving
Post by Nitrate »
I should mention that I modified an early steering wheel to work on my 81'. I installed the pin that allows the directional to work. This setup does not allow the standard horn to work. I just need a simple circuit to activate the horn using a dash mounted push button switch. Could someone tell me how to do that? Thanks Rich B.
ORFORD2004
Post by ORFORD2004 »
Don't you have a wire that come in the center of the wheel steering?
bobplyler
Patron 2022
Patron 2022
Post by bobplyler »
I hooked one up about 20 years ago. My horn button stopped working, and I had to have
one to pass safety inspection. If I remember correctly, it hooks to a relay that's accessable
by removing the glove box.
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
Nitrate
Post by Nitrate »
If I found the Gray/Black and Violet/Black that are attached to the original horn contacts in the steering column and put a switch between them would that work? RB
Nitrate
Post by Nitrate »
Correction. Not a switch between them but a switch in ONE of the wires. A push button switch. RB
baltobernie
Post by baltobernie »
The switch goes between those wires. You can test by touching them together. But some state inspection agencies require that the horn button be where the manufacturer placed it.
Nitrate
Post by Nitrate »
Thanks for the replies. Anyone know the best place to access the Violet/Black wire? An area with a slight bit of elbow room? RB
ORFORD2004
There is only 1 wire for the horn. You ground it to activate the horn. Washuko send me a momo horn button with 2 legs. I put one wire under the steering bolt for ground. And attach both to the switch.
Picture to come.
I don't think connecting the grey/black and black/violet wire to a switch will work.
The black/violet wire is from the horn relay coil and goes to the slip ring on the steering wheel hub. The grey/black wire connects the slip ring to the horn button. The black/violet wire needs to be switched to ground for the horn to work. There are 2 connectors that come out of the steering column the one with 8 cavities has the black/violet wire in it. It is usually located behind the instrument cluster above the fuse panel.
baltobernie
My bad. I stand corrected.
