Wipers now working with 89 firebird wiper switch
v6spider
Your car is a: 4.3L V6 Powered 1972 124 FIAT Spider
Post by v6spider »
Finally figured out how to make the wipers work with the wiper switch that is on my tilt steering column that I got from an 89 Pontiac firebird. It took three spdt relays and a considerable amount of head scratching. I had one snafu with one of the relays having a different pinout than the other two relays that I had just bought. Those had diagrams on top.. The other one didn't.. Then the wipers were clocked 180° out. They wouldn't park at the bottom they parked up top.. And the wiper blades were to long... But after all of that they now work beautifully.
http://www.v6spider.com
RoyBatty
Your car is a: 1975 124 Spider - 1971 124 Sport Coupe
Re: Wipers now working with 89 firebird wiper switch
Post by RoyBatty »
Well done!
Share a diagram for future modders?
v6spider
Post by v6spider »
RoyBatty wrote:Well done!
if you are really interested I could draw it out. For reference the stock FIAT Spider wiper switch is a double pole triple throw switch.
Pole 1 is fed by the white wire with a black stripe
Pole 2 is fed by the yellow wire with a black stripe
-------------- 1-------2
Off --Pos1= Yellow --- NC
Del - Pos2= White ---- Red
On --Pos3= NC --- --- Grey
I eliminated the delay position and use 2 single pole double throw relays to mimic the off and on positions. I used a third single pole double throw relay for the fast and slow switch. My firebird switch is a single pole 3 throw switch. Position two energizes the on off relays while the speed relay is not energized which is the slow speed...position 3 energizes all three relays for fast speed... Position 1 is all relays not energized.. The off position
