bradartigue wrote:According to my wiring diagram it is the brown wire with the red stripe, or just brown. Whichever run is +12V and has a female connector and is long enough to reach the carburetor.
I've only seen pink or blue running to the Solenoid but i did do a quick wire trace down this morning i see the wire to all the relays are all in the wire harness coming from the dash but they break off into (2) different groups, all wires going to the relay area all go to these 3 connectors i photo number 1 and 2 the other groups seems to go to all sensor than are on something such as starter, oil pump pressure reader, so i'm getting closer to figuring this out as the second group all are connected to something that has a sensor on it but these 6 wires so i believe 1 has to go to the carb.
All 3 connectors lead to relays only.
Relays remove to trace wires.
Second group of wires are in this bunch see photo half are connected to the starter oil pump, radiator heat sensor, etc but these 6 in photo number 4 aren't connected to anything at the moment .
Looking for which one goes to the Carb Start/Stop Solenoid.
