I have been the happy owner of a 1974 CS-1 US-model for 25 years. The original 1756cc engine was replaced by a brand new 2L engine for a Ritmo (Strada) 130TC, many years ago. I kept the stock (or similar) single carb and the stock exhaust. It was adjusted on a "rolling road" and put out 113 HP at the time. I am finally going to give it the carbs and exhaust that it deserves
- Dual 40 IDFs (Made in Spain) (With choke)
- K&N "Lunch-Box" filters
- A swept-back, Alquati look-alike, intake manifold
- Facet fuel pump
- Malpassi Filter King pressure regulator
- Compu-Tronix distributorless ignition system (partly to avoid collision with intake manifold)
- 4-2-1 Abarth exhaust from Spider-Point.com
Any comments/suggestions on this are more than welcome.
Here are my questions: I am being told by two Weber suppliers (Germany and UK) that I will need to machine down the spindles and nuts where the two carbs meet, in order to be able to mount them on the intake manifold. Have any of you done this before? What exactly must be done? Will there be problems with linking the two carbs together after the "operation"?
To solve the linkage problem I am planning to do as suggested by Kendickson http://www.kendickson.com/car/idf/idf/index.html
Do any of you have other suggestions?
I am also in doubt what to do with the crankcase breather tube. It doesn't seem to be possible to attach it to one of the air filters. In some of the comments here I have seen suggestions to install a small K&N look-alike filter on the end of the hose. Will that be OK? Will there be oil fumes coming out of the filter, making the engine compartment dirty? Or will there be other problems with this set-up? Do you have other suggestions to solve this problem?
I have found the set-up parameters for the DCOE carbs originally installed on the 2L 130TC Ritmo engine. They look like this:
Primary / Secondary
Venturi 32,0 mm / 32,0 mm
Main Jet 138 / 145
Air Correction Jet 175 / 190
Emulsion Tube F41 / F41
Idle Jet 58 / 54
Idle Air Bleed - / 180
Accelerator Pump Jet 35 / 45
Accelerator Pump Delivery 3.5 cc per 10 strokes
Fuel Inlet Needle Valve 1.5 mm
Float Setting 6.75 to 7.25 mm
(don't think I understand all of it, though)
Is this how I should order the two new IDFs?
I am really looking forward to this upgrade and hope I will get a much more "lively" car. Hopefully some of you experts here will be able to give me advice on this. I have read lots of the threads and I see that there are some very experienced and knowledgeable folks here.
