I bought SS brake lines and have an installation question for my esteemed colleagues here on the forum:
When installing them, do you do one line at a time, bleed, and move to the next, or do you just take the whole system down install them all and then refill and bleed? My brake fluid was recently replaced, so I have no need to drain the entire system, and I am thinking that it might be easier to just do one segment at a time?
Any advice appreciated. Thanks.
Pete
SS Brake Lines Question
Re: SS Brake Lines Question
Pete, I'm not sure what the answer is. About three/four years ago I replaced all the hoses and found bleeding brakes to be a PITA. However, the best method for me has been replacing hoses one at a time and then bleeding the entire system using the speed nipples. I start from the wheel furthest from the master cylinder and work to the closest wheel to the master. I then repaet the entire process. I've found starting far away and two trips around the car to work well.
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
- bradartigue
Replace all of the parts and then bleed. Otherwise you'll be chasing air bubbles a week later. Use a pressure bleeder or speed bleeders. Don't even try manual bleeding with the silly cup and hose, it will drive you nuts. If you are replacing the MC bleed it before connecting the lines, preferably on a bench so you don't get brake fluid everywhere.RRoller123 wrote:I bought SS brake lines and have an installation question for my esteemed colleagues here on the forum:
Pete
Every time I do this when I'm done and happy with the brakes I spray engine cleaner all over the MC area and the brakes to get any residual brake fluid off the body, it will destroy your paint.
Also a nice trick is to replace gold fluid with blue, and blue with gold (ATE makes both colors) so you'll know when you are getting fresh fluid.
1970 124 Spider
http://www.artigue.com/fiat
Thanks guys.
This might help
http://www.youtube.com/watch?v=L0oUejw5Edc
http://www.youtube.com/watch?v=MfTmlOZbXgs
Brake Bleeding in the Fiat 124 Spider:
Like many cars that use compensators to prevent lockup of the rear brakes under hard braking, the Fiat 124 Spider rear brakes must be bled with the rear axle supported. Otherwise, the compensator valve will fully close, and no fluid will be allowed to flow to the rear brakes.
On the 124, jack the rear of the car at the differential pumpkin. You can use a block of wood in between the jack and pumpkin to prevent damage. Place the jackstands as far outboard as possible on the rear axle tubes. Bleed the brakes farthest to closest (i.e. RR, LR, RF, LF) from the master cylinder.
Alternatively, if you choose, you can bleed the brakes with the car fully on the ground. Though, using this method, access is tricky and it takes nearly as long as jacking the car in the first place.
Note:Only get under a car that has been supported with jackstands; a jack alone is only meant to lift and can fail if holding a car up by itself.
