Aluminum hubs
Aluminum hubs
Does any one know where I can get aluminum hubs ,other then miller mule ( Jason
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
Re: Aluminum hubs
Any good machinists around you? The one near me make them for his dwarf cars.
Chris
Chris
Re: Aluminum hubs
Like a mechanic machines or a foundry?narfire wrote:Any good machinists around you? The one near me make them for his dwarf cars.
Chris
Are they made in one piece or 2 piece and welded
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
Re: Aluminum hubs
There just one piece,correctpaintdudeluke wrote:metal lathe.
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
- Your car is a: 1975 Spider
Re: Aluminum hubs
I am assuming that Jason is out of stock
son has 78 spider
son has 78 spider
Re: Aluminum hubs
Yes,he don't know when he will get some,but I will get someBEEK wrote:I am assuming that Jason is out of stock
I need some one to send me a hub,so they can copy it
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
Re: Aluminum hubs
I'm thinking they would be made out of one block. For a couple or 4 I'd be thinking they might be a bit pricey. I could ask, but if one could take a pattern from an original and then use one of those fancy cad milling machines....
Re: Aluminum hubs
It be the same as the steel hub ,I'm presuming , 200 per hub at Jasonnarfire wrote:I'm thinking they would be made out of one block. For a couple or 4 I'd be thinking they might be a bit pricey. I could ask, but if one could take a pattern from an original and then use one of those fancy cad milling machines....
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
Re: Aluminum hubs
i want a set made with a different bolt pattern 5x114.3mm, as opposed to 4 x 98mm, this is for my project car, i already have the rear hubs for the irs, those have the 5x114.3mm pattern, the brake rotors and wheel selection is much greater at that pattern
son has 78 spider
son has 78 spider
- MrJD
- Your car is a: Looking to ask questions about a 79 2.0
Re: Aluminum hubs
$800 for hubs + shipping/tax. Why do you want these fiat218?
- azruss
Re: Aluminum hubs
there are shops around that make adaptors for ATVs. I doubt if you will do better than a couple of hundred a whack. The turning is the easy part. the hard part is getting the holes concentric. This requires a mill, preferably a CNC mill.
Re: Aluminum hubs
Just the front, lighter at the wheelsMrJD wrote:$800 for hubs + shipping/tax. Why do you want these fiat218?
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
Re: Aluminum hubs
Never thought of that part, I just figure they would copy the steel onesazruss wrote:there are shops around that make adaptors for ATVs. I doubt if you will do better than a couple of hundred a whack. The turning is the easy part. the hard part is getting the holes concentric. This requires a mill, preferably a CNC mill.
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
