But what causes this? Seems like the gas goes all the way back to the tank during the downtime and needs to be pumped from there instead of it staying in the gas line. Isn't there a check valve in there to prevent this
sptcoupe wrote:Check the accelerator pump diaphragm as Mark says, then swap out you mechanical pump fir an electric pump and this problem will be gone forever.
Holy crap we agree! And there was much rejoicing...majicwrench wrote:Brad and I differ once in a while, on this I couldn't agree more. To do a hack job of installing an electric pump, create more wiring issues, fuel leak, yuk. FIx the problem. Yes, accel pu,mmp diaphram can leak letting fuel drain when it sits. Is it the issue?? You need to look. Accel pump is on side of carb facing L fender. Square houising four small bolts. Fuel should not be present under this thing stick your finger under there. Mechanical pumps have a flapper valve so fuel can't drain back. Often stuff under valve letting fuel in line drain back.
Fuel cannot really "drain back" from carb although it can evaporate,from the heat of a hot engine after shutdown.
I cleaned the flapper valve in fuel pump in my 72 3-4 years ago, what a difference.
Keith
Thanks for the help in locating the accelerator pump. Will look at it. If it's not that, then I will check the flapper valve on the fuel pump. Could just be a build-up of gunk or junk blocking it's operation, thereby letting the fuel drain back, is that correct?bradartigue wrote:majicwrench wrote: Accel pump is on side of carb facing L fender. Square houising four small bolts. Fuel should not be present under this thing stick your finger under there. Mechanical pumps have a flapper valve so fuel can't drain back. Often stuff under valve letting fuel in line drain back.
Keith
