Steering wheel refinish
SpyderNoobe
Post by SpyderNoobe »
Hello -
I have a 80 spider that the original steering wheel is rusted and the plating/finish coming off. Is there anything to be done to save it? Can it be refinished or should it just be replaced?
Thanks in advance
rlux4
Patron 2022
Patron 2022
Re: Steering wheel refinish
Post by rlux4 »
A quick search turned this up;
http://www.fiatspider.com/f08/viewtopic ... el#p191654
Several people have done the same thing and the results seem pretty nice.
Ron Luxmore
rlux2n2@gmail.com
joelittel
Post by joelittel »
I did the same thing to mine (sanded it down, using finer and finer grit papers, followed up with quite a few layers of clear and then sanded that down with 000 steel wool until it was very smooth, then hit it with a final coat of clear).
It looks good and has lasted, but it doesn't have the same appeal as a professionally chromed piece. From a distance my buddy could tell that it was covered with a clear coat.
wizard124
Post by wizard124 »
From an earlier post:
I used steel wool to remove the old finish. Then all Rustoleum products, grey primer, metallic silver, and clear coat. I found out the hard way that if you omit the primer, the metallic silver will sort of dimple, leaving a terrible finish. :( Acetone to remove. :)
Post by RRoller123 »
if you take a little red paint on a q-tip and rub it into the "Ferraro" lettering, it looks pretty good. 8) I don't have a pic unfortunately to post. I also cut away the torn flaps of rubber moulding at the spokes, as you did, it makes a nice difference.
