brake pads
fiat218
brake pads
Post by fiat218 »
here i have 2 differnt size pads, you can see the thickness
one box ( thick pads ) sayd front pads/ im not sure if they are or not, it some box i have gotten with a car
can some one tell what the differnce is and why
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
4uall
Re: brake pads
Post by 4uall »
I believe the thicker pads are for the front and thinner are for the back. Be sure that they are not thinner due to wear (hard to tell from photos) Go here and search brake pads you will see differences
http://www.autoricambi.us/cgi/commerce.cgi
manoa matt
Re: brake pads
Post by manoa matt »
The thicker pads are fronts. The rear pads are thinner than the ones pictured. Also rear pads have a small nub on the outboard face of the backing plate to engage the caliper piston.
The thinner pads are also fronts, but may be for a different application/car. If you install them, the caliper piston will be further out and the chance of the pads wearing unevenly or not seating properly will be increased.
fiat218
Re: brake pads
Post by fiat218 »
I know what you mean by the pin, there is none in either set, they are both new
I have 4 thick, 4 thin
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
fiat218
Re: brake pads
Post by fiat218 »
manoa matt wrote:The thicker pads are fronts. The rear pads are thinner than the ones pictured. Also rear pads have a small nub on the outboard face of the backing plate to engage the caliper piston.
What the pin for in the pad, I realize that it goes in the slot of the piston.can I put the skinny ones on the back with out the pin.? Just asking
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
manoa matt
Re: brake pads
I think those are front pads for another fiat model with thicker rotors or a caliper with a shorter piston. Regardless they are too wide to fit into the rear calipers. The rear Fiat 124 pads have a friction compund that is very thin, less than 5mm.
fiat218
Re: brake pads
Post by fiat218 »
Well all the brakes pad have been replaced with all new
Bled them, they are working great , just waiting for the starter and lite kit from mark
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
