Signal and Flasers Stoped working
all my signal lights and the flashers stoped working... could it be a fuse or flasher relay? I have a 82 spider
- azruss
Re: Signal and Flasers Stoped working
check your flasher switch.
your signal lights work through fuse A or 1 which has power in start and run position of the ignition switch. Your emergency flashers work through fuse I or 9 and that has power all the time so your emergency flashers can operate with the ignition switch off. Have you exercised your emergency hazard switch. everything goes through it.
There is one flasher relay and it operates both the signal and hazard lights. I think it needs to see a complete circuit to switch or click. If your green dash indicator bulb fails I am not sure the flasher relay will work. If you think everything worked properly and then just quit I would check the flasher relay and the dash green indicator bulb first. It is unlikely that both fuses failed unless you have a short.
Thanks guys. I hope I can tackle it tonight and will update you..
Thanks again guys... the Hazard switch was actually unplugged.. all fixed...
whoooooooooo hooooooooooooooooooooooo
Yea what a relief. I didn't think I would be able to go to Dixie Fest in Winston Salem NC..
I have the same problem and have been troubleshooting for three days.......can't figure it out but now that you say everything goes through the flasher switch i think thats the problem because it came totally apart when I took out the console and I can't put it back together. Where can I buy a new switch.....? What vendor ......please advise. International_auto.......Mark doesn't have it I don't think
