HELP - turn signals, flasher, interior light died
donerehart
Your car is a: 1976 spider
Post by donerehart »
I was working on my dash tonight and shorted a big red wire and lost my emergency flasher and interior light... Not sure where to go from here...help...
Thank you!
Don
76 Spider
St. Louis, MO
Re: HELP - turn signals, flasher, interior light died
check the fuses
donerehart
I checked all the fuses and they are fine...
76 Spider
St. Louis, MO
donerehart
The turn signals now work, but my emergency flasher and my interior light does not...any ideas...All fuses appear fine...
76 Spider
St. Louis, MO
Both the curtsey and hazard lights operate off of fuse 9 which is hot all the time. If you are sure the fuse is good I would suspect a poor connection at fuse panel. The power does jump to a few connectors before getting to the hazard switch and curtsey light
donerehart
Thank you...I will trace things from there.
76 Spider
St. Louis, MO
donerehart
Found inline fuse that was blown...all is back...thx for the help fiat team!
76 Spider
St. Louis, MO
