was thers some one who had a photo of a template? as to where he mirror on the driver side would sit
i have the mounts under the inside of the door but i would never be able to pin pot them from the top to get the mirror in the right line up with the pre mounted nuts inside the door
can some one help me get a template
thanks
1980 2000
TEMPLATE
Re: TEMPLATE
Could you get a drill in there and drill small pilot holes up from the inside to show the locations?
Re: TEMPLATE
no, i don't see how i could. possible if i remove the whole inside or the track and glass, and that ain't going to happenRRoller123 wrote:Could you get a drill in there and drill small pilot holes up from the inside to show the locations?
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
- azruss
Re: TEMPLATE
in the gray area below the header on this page is a section called "view your posts". if you click on that, you will find a blog titled "side mirror" that you posted on 6/16/12. I posted my pix there.
Re: TEMPLATE
ok thanksazruss wrote:in the gray area below the header on this page is a section called "view your posts". if you click on that, you will find a blog titled "side mirror" that you posted on 6/16/12. I posted my pix there.
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
