Replacing rear pads, rebuilding rear calipers, replacing rear rotors, master cylinder and emergency brake cable due to some braking problems - initially emergency cable barely stops one side and not the other (now doesn't stop either rear wheel), car pulls to the right under hard braking, and pedal seems to move slowly under constant pressure, then when quickly released and re-applied, the pedal pressure feels harder.
In any case.....really could use some help here.
Although referenced many times, the mirafiori article IS very helpful, but bypasses some specific (& essential) details. like how to remove the emergency cable off the caliper cam lever and more importantly, how to orient the plunger, the Pawl (metal wedge) and cam lever when re-assembling !! My comprehensive FIAT shop manual shows no better details...
And finally, the mirafiori article shows what appears to be 3 spring washers and a separate & different washer. The service manual shows 2 "disk springs" and 1 "thrust washer".
The one caliper I disassembled shows what appears to be 3 "spring"
or "disk" washers ( which look like 6 washers arranged as ...() () ().....and here's the kicker...NO THRUST WASHER !! So, 1) are they supposed to be 2 disk washers as per Service manual? Or 3 disk washers as per Miafiori article ? And
2) what happened to the THRUST WASHER on the caliper I disassembled - see pic?
Both rear calipers are supposed to have been purchased rebuilt before i got Luigi, but as I haven't removed other caliper, I don't know what the other caliper has in disk and thrust washers..
Can anyone answer my questions??
And does anyone have a pictorial or tutorial on how to re-assemble the rear calipers with all the important details???
Many thanks,
