Fuel pump fuse
cbrown1469
Fuel pump fuse
Post by cbrown1469 »
Guys
Can you assist?
Have intermittent non start getting spark, it will fire for 1 second ( which is obv down the cold start). However, have the fuse box down and the relay plate on passenger side and I cannot for the life of me trace a brown wire with white stripe to check fuel pump relay!
I do see a red and a white inline fuse holder but not with those wire colours. I checked them regardless and the fuses within are ok.
Any ideas?
Thanks in advance for any responses
Craig
tartan18
Your car is a: 1975 Fiat 124 Spider
Re: Fuel pump fuse
Post by tartan18 »
What year is your car?
Jim MacKenzie
1975 Fiat Spider
rlux4
Patron 2022
Patron 2022
Re: Fuel pump fuse
Post by rlux4 »
The fuse holder for can be a bear to find the first time. It's up behind the main fuse panel amongst the rat's nest of wires there. It may be out of sight laying on top of a brace. The fuse holder itself is red with white connectors on each end.
Ron Luxmore
rlux2n2@gmail.com
cbrown1469
Re: Fuel pump fuse
It's a 1980 and I can confirm tat there are 3 inline fuses. 1xblue, 1xred,1xwhite.
Cleaned and checked and now running again. If I break the white one whilst running it cuts out.
rlux4
Patron 2022
Patron 2022
Re: Fuel pump fuse
Post by rlux4 »
Good going. That's how I learned a lot what I know, disconnect a component and see what happens.
You have different color wires than normal, but that's not unusual for Fiat. 1980 is the first year for FI in our cars, so it doesn't suprise me that there are differences.
Ron Luxmore
rlux2n2@gmail.com
