Fuel gauge is off
AZ79
Fuel gauge is off
Post by AZ79 »
My tank always measured completely full, so I bought a new sending unit, but it didn't help anything. So I took out the new unit and attached a ground wire to it, and with the key on I moved the float lever up and down. I see that my gauge reads totally full when the lever is in the up position, but it only just goes down to under the 4/4 mark when it's all the way down.
Is there a solution for this?
AZ79
Re: Fuel gauge is off
Post by AZ79 »
The only thing I can think it could be is that when I bought the car (a '79) I switched the gauge with one from a '74.
It's always read full, so I've always figured it was just the sending unit.
Would it make a difference which year the gauge is? I couldn't see how...It hooked right up just the same...
vandor
Post by vandor »
It does not matter what year the gauge is from. Do you have your original one?
Gauges rarely go bad, but it could happen.
At first I thought maybe the wires are reversed, but then it would do the opposite, show full when the float is all the way down.
AZ79
Post by AZ79 »
Nah, I gave my old gauge away when I sold my parts car..
AZ79
Post by AZ79 »
Well, it turns out it was the gauge after all. I put a new one in and it works perfectly. :)
So this is one case of a bad fuel gauge.
