I have a 76 Spider and this last week when I turn the key sometimes, the fuel pump does not turn on. If I take the key out and start the process over, everything works fine. I'm pretty sure the problem is in the ignition switch itself...anyone have any ideas on how to work this problem out?
Don
Ignition Switch Question
- Your car is a: 1976 spider
76 Spider
St. Louis, MO
St. Louis, MO
- Your car is a: 1982 Fiat 124 Spider
Re: Ignition Switch Question
Replace the switch. A few folks have successfully disassembled the switch and cleaned the contacts.
