Center console heating up
dmwhiteoak
Your car is a: 1972 Fiat 124 spider
Post by dmwhiteoak »
Has anyone had the problem with the center console heating up on the side enough so that it is burns your bare leg? Not to the point that it blisters but you can't hold your leg on it. This is only as the car is mobil, it cools down quickly at every stop. In cooler weather it does not heat up at all. Thinking I need more insulation. What do y'all think ?
Dennis Modisette
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
calvinconrad
Your car is a: 1976 spider
Re: Center console heating up
Post by calvinconrad »
mine used to get pretty hot. replaced some of the old insulation with new and it has cooled down a lot.
1976 124
4uall
Post by 4uall »
I just completed my flooring( POR15, padding, carpets etc) and it made an incredible difference with the sound and heat shield. I am getting lots of compliments in regards to no heat and how quiet Fiona is now. :mrgreen: Check out my photo link for more details
EZ Cool by itzebtze, on Flickr
Found the source of the fumes getting in.
Shifter Panel removed by itzebtze, on Flickr
This made all the difference when it came to eliminating the fumes inside.
Inner transmission/ shift boot by itzebtze, on Flickr
dmwhiteoak
Jay, I have seen all your pics and followed your threads. I want the insulation you have and I will make it happen. I just didn't know if this was common or if my trany was putting off more heat than what it should. You have done good work with your car and will have a jewel when complete. I just hate to have mine down long enough to work on it.
Dennis Modisette
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
4uall
Post by 4uall »
I hear you. Good luck with resolution. :mrgreen:
124JOE
Post by 124JOE »
my shifter handle was hot as hell when i had a bad tranny "no 2nd gear"it got so hot
it was smoking thru the boot smelling up the car.exh manifold gasket was bad ,adding more heat
that was awhile ago
ps i talked with my body guy.he said"dont seal up the drains on the floor"
its a convert so they leak and need to drain
4uall
Post by 4uall »
124JOE wrote: ps i talked with my body guy.he said"dont seal up the drains on the floor"
glad I left all the holes uncovered (well, all except these)
Rust Hole by itzebtze, on Flickr
Rust hole repair (drivers side) by itzebtze, on Flickr
Drivers side rear after Marine Clean applied by itzebtze, on Flickr
Fiberglassed the surprise hole then POR15 by itzebtze, on Flickr
POR15 applied by itzebtze, on Flickr
4uall
Post by 4uall »
New home made carpeting
TX82FIAT
Post by TX82FIAT »
I found the same thing. Trans was good but I had a lot of heat on the passenger side trans tunnel. Then i fixed some rust in the floor with POR 15 and added a layer of insulation. This past weekend i drove it for about an hour and that area was not even warm to the touch. I did add a layer of insulation and then a very thin 3/16 layer of mold resitant carpet over top of the hump with a cut out for the shifter and some wires.
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
