Lubing power window motor gears? What lube is recommended?
While I have the door panels off,I want to lube the power window regulator and gears. What is a good lube/grease to use? Any other parts of the window worth lubing or inner door? Thanks.
- KidDingo
- Your car is a: 1981 Fiat Spider 2000 FI 5-spd
Re: Lubing power window motor gears? What lube is recommended?
My car doesn't have power windows, but I did this same job a few weeks ago.Fiat88 wrote:While I have the door panels off,I want to lube the power window regulator and gears. What is a good lube/grease to use? Any other parts of the window worth lubing or inner door? Thanks.
You can buy an aerosol can of lithium grease. Make sure you get the one with a directional nozzle similar to the ones you get with WD40.
I wound the up the windows as far as they would go so as not to spray grease on the glass, then sprayed each of the pulleys. Make sure you also do the entire door lever mechanisms, including the catch mechanism. Some parts inside the door were tough to get at.
I also did the door hinge and the U-shaped door check (looks like this: http://www.vickauto.com/newstore/index. ... ts_id=2497).
Amazing how a good greasing can make a big difference.
_______________________________________________
Michael
Michael
