Headlight Toggle switch
cricketland
Your car is a: 1980 spider 2000
Post by cricketland »
For those seeking an aftermarket headlight switch, either rocker or toggle EG: off on on I have found them after searching for this switch function High and low. I found that Hella produces them , if you search the site you will find the toggle and rockers.
I'm adding Fog Lights and I was hoping to install a matched set of illuminated rocker switches in the dash, Matched in style and size. Fog's to be ON/ Off and headlights Off , ON, ON
Already cleaned up and re attached engine compartment grounds to stud post w/o grounding basket then applied dielectric grease to virtually every contact EG: in Engine compartment, Under dash, light lamp connections. Installed a headlight relay kit, lights bright and solid!!
Next to install a relay kit for the starter and new wire from alternator to starter.
Fog lights have relay kit and will pull power independent of headlights.
http://www.hella.co.nz/3-254/product/toggle-switches
Oops just realized this is Hella New Zealand, I sent a message to Hella to find out where/ how one can purchase off,on,on switches in the USA.
Cricket
lanciahf
Re: Headlight Toggle switch
Post by lanciahf »
Cricketland? Mick R U okay?
cricketland
lanciahf wrote:Cricketland? Mick R U okay?
si mi amigo , thank you for asking :?
Cricket
