1980 fiat 2000
fiat218
1980 fiat 2000
Post by fiat218 »
see that piece where the wire connects inside the dizzy and then that wire connects down to the electronic thingy, i assume. i need that wire or that whole piece that goes in the dizzy. HOW does that come off? i see 2 screws and well now what ? is that called the pic up coil?
better photo Image
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
fiat218
Re: 1980 fiat 2000
Post by fiat218 »
what this called?
and the wire is connected to this piece and goes in the dizzy. so what the other end called?
thanks
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
Snoopy
Your car is a: 1980 CS0 2000 f.i. US [Build 1979]
Re: 1980 fiat 2000
Post by Snoopy »
Electronic Ignition Pickup
for example here:
http://www.international-auto.com/index ... sid=866864
Yes only two screws... then lift...
Ignition Control Module
for example here:
http://www.international-auto.com/index ... sid=867030
CS0 2000 f.i. 79, Abarth 500C 595 2013, Ford C-MAX 1.0 Ecoboost 2015
fiat218
Re: 1980 fiat 2000
Post by fiat218 »
so it suppose to just come off then?
would that possible be a local parts store part? i see the modular is a gm product
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
aj81spider
Re: 1980 fiat 2000
Post by aj81spider »
My local Autozone had one compatible with my Fiat.
A.J.
2006 Corvette
fiat218
Re: 1980 fiat 2000
Post by fiat218 »
thanks i got it off, it was just stuck on the plate , i was not sure how it came off so now it simple. . now i can show u the wires, im thinking this is why there no spark Image
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
WYSpider
Re: 1980 fiat 2000
Post by WYSpider »
NAPA also has control modules for the spider.
Re: 1980 fiat 2000
Yes the frayed wires in the pick up will cause intermittent and or total loss of spark.
I would try replacing the pick up assembly first. The control module does not need to be replaced every time the pick up is replaced. Also pay attention to the instructions that come with the new pick-up. The magnet has to be installed with blue line exactly as the instructions state.
azruss
Re: 1980 fiat 2000
Post by azruss »
when you buy the new pick up unit, it comes with a base. make sure you dont put the base on upside down. when you reinstall the ignition module in the heat sink, you need a good conductive paste for between the 2 parts (dielectric silicon?).
ga.spyder
Re: 1980 fiat 2000
Post by ga.spyder »
I always keep a spare magnetic p/u in my toolbag.Those wires are soo easy to fray and leave you dead in the water.I pull my cap every few months and check the condition of those wires.A simple trick is to twist the two wires together to shorten them slightly(for some reason the wires are always too long),then wrap them with electrical tape.
Craig Nelson
Fling It Around Turns !
fiat218
Re: 1980 fiat 2000
Post by fiat218 »
ok thanks to you all. i will get it done
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
fiat218
Re: 1980 fiat 2000
Post by fiat218 »
what happens if it was upside down?
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
